Basic Ethernet2 Server no-go
Just tried basic Ethernet server code using Ethernet arduino library, but I had to change one to Ethernet 2, because I think I have a W5500 chip.
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet2.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
byte mac[] = {0xAD, 0xBE, 0xDE};
IPAddress ip(192, 168, 1, 177);
EthernetServer server(80);
 while (!Serial)
 Ethernet.begin(mac, ip);
 server.begin();
 Serial.print("server is at ");
 Serial.println(Ethernet.localIP());
 if (client)
  Serial.println("new client");
And here’s what it had to say about it.
C:\Program Files\Arduino\libraries\Ethernet\src\EthernetClient.h:8:7: warning: type of ‘vtable for EthernetClient’ does not match original declaration
class EthernetClient : public Client {
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src\EthernetClient.h:8:7: note: previously declared here
C:\Program Files\Arduino\libraries\Ethernet\src\Ethernet.cpp:6:9: warning: type of ‘_state’ does not match original declaration
uint8_t EthernetClass::_state[MAX_SOCK_NUM] = {
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src\Ethernet2.cpp:15:9: note: previously declared here
uint8_t EthernetClass::_state[MAX_SOCK_NUM] = { 0, };
C:\Program Files\Arduino\libraries\Ethernet\src\Ethernet.cpp:8:10: warning: type of ‘_server_port’ does not match original declaration
uint16_t EthernetClass::_server_port[MAX_SOCK_NUM] = {
C:\Program Files\Arduino\libraries\Ethernet\src\Ethernet.h:19:19: warning: type of ‘_server_port’ does not match original declaration
static uint16_t _server_port[MAX_SOCK_NUM];
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src\Ethernet2.cpp:16:10: note: previously declared here
uint16_t EthernetClass::_server_port[MAX_SOCK_NUM] = { 0, };
C:\Program Files\Arduino\libraries\Ethernet\src\Ethernet.cpp:136:15: warning: type of ‘Ethernet’ does not match original declaration
EthernetClass Ethernet;
C:\Program Files\Arduino\libraries\Ethernet\src\Ethernet.h:39:22: warning: type of ‘Ethernet’ does not match original declaration
extern EthernetClass Ethernet;
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src\Ethernet2.cpp:209:15: note: previously declared here
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src\EthernetUdp2.h:50:7: warning: type ‘struct EthernetUDP’ violates one definition rule
class EthernetUDP : public UDP {
C:\Program Files\Arduino\libraries\Ethernet\src\EthernetUdp.h:44:7: note: a type with the same name but different layout is defined in another translation unit
C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2\src/EthernetUdp2.h:50:7: warning: type ‘struct EthernetUDP’ violates one definition rule
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for “Dhcp.h”
Used: C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2
Not used: C:\Program Files\Arduino\libraries\Ethernet
Using library Ethernet2 at version 1.0.4 in folder: C:\Users\Notshowingmynamelol\Documents\Arduino\libraries\Ethernet2
Using library SPI at version 1.0 in folder: C:\Users\Notshowingmynamelol\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI
Using library Ethernet at version 1.1.2 in folder: C:\Program Files\Arduino\libraries\Ethernet
exit status 1
Error compiling for board Arduino/Genuino Uno
Had to cut off most of the error messages, but here it is.
Your code has unnecessary #include directives that caused the Ethernet library to be brought in as well as the Ethernet2 library, which caused conflicts. The solution is to remove the unnecessary #include directives, leaving only the one for Ethernet2.h:
 while (!Serial)
 server.begin();
 if (client)
Thanks! I just used the directives that appeared when I selected "Ethernet", or In "https://www.arduino.cc/en/Tutorial/WebServer", or in my Arduino programming book. Sure I don't need SPI.h or Etheretclient.h if I expand my code?
As long as you're using Arduino IDE 1.6.6 or newer you only need to include Ethernet2.h. It was necessary to include those other files with Arduino 1.6.5 and older so that's why you see those lines still in the examples and tutorials for backwards compatibility but the Arduino IDE has been improved since then.
Thanks, but I had a problem with my serial monitor displaying 0.0.0.0, so I checked and found out I ended up getting a W5100 chip :o :frowning: So I just need Etherent.h now? Does W5100 even have a client function?
I changed my code to this:
#include <Ethernet.h>
int Svr=1;
IPAddress ip(129, 186, 1, 172);
 while (!Serial)
 server.begin();
 Serial.print("server1 is at ");
 while (!client)
 Svr++;
 Serial.print("server");
 Serial.print(Svr);
 Serial.print(" is at ");
The compiler had no errors, but the Serial Monitor had this:
server1 is at 129.186.1.172
despite me going to “http://129.186.1.172/”, which displayed this:
This site can’t be reached
129.186.1.172 took too long to respond.
ERR_CONNECTION_TIMED_OUT
