Basic Grove sensor declaration error
Hi, I assume this problem will probably be the simplest error for most of you guys.. Please help this clueless beginner out. So I was trying to use Grove temperature & moisture sensor to make a simple code to blow-off a CFL lamp and then while trying to find a threshold value for the humidity, which required me to update this code:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN A0     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
    Serial.println("DHTxx test!");
    dht.begin();
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    // check if returns are valid, if they are NaN (not a number) then something went wrong!
    if (isnan(t) || isnan(h))
        Serial.println("Failed to read from DHT");
        Serial.print("Humidity: ");
        Serial.print(h);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(t);
        Serial.println(" *C");
and from very since I got an error saying:
DHTtester:32: error: 'dht' was not declared in this scope
So I put a declaration of 'DHT' and 'dht' as the internal instruction included says:
int DHTPIN = A0;
int DHTTYPE = DHT22;
But the same message comes up highlightin this line in the script:
Can someone tell me what I am doing wrong?
I guess you get other errors before that one you posted. My guess is you didn’t install the Adafruit DHT library. Did you check that?
