I'm a relative newcomer to Arduino but have succesfully completed a couple of projects. I'm now moving on to a can bus project and need some help getting started with FlexCAN (on a Teensy 3.6).
My aim is to read 4 can bus messages from a boat engine (0x280, 0x288, 0x380 and 0x588) and transfer some of the data to a NMEA2000 network. I can deal with the NMEA part using Timo Lappalainen's code, and I can read the engine canbus messages with Collin80's FlexCAN code. Where I'm struggling is getting the can bus data out from FlexCAN and into NMEA.
I have been advised to:
create new module for handling standard CAN messages with interrupts. Then just poll the buffer
Using Collin80's code I can receive the messages and view them on serial monitor.
#include <FlexCAN.h>
class ExampleClass : public CANListener
public:
void printFrame(CAN_message_t &frame, int mailbox);
bool frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller); //overrides the parent version so we can actually do something
void ExampleClass::printFrame(CAN_message_t &frame, int mailbox)
Serial.print("ID: ");
Serial.print(frame.id, HEX);
Serial.print(" Data: ");
for (int c = 0; c < frame.len; c++)
Serial.print(frame.buf[c], HEX);
Serial.write(' ');
Serial.write('\r');
Serial.write('\n');
bool ExampleClass::frameHandler(CAN_message_t &frame, int mailbox, uint8_t controller)
printFrame(frame, mailbox);
return true;
ExampleClass exampleClass;
void setup(void)
Serial.println(F("Hello Teensy Single CAN Receiving Example With Objects."));
Can0.begin(500000);
//if using enable pins on a transceiver they need to be set on
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
Can0.attachObj(&exampleClass);
exampleClass.attachGeneralHandler();
void loop(void)
Serial.write('.');
Question 1: Where are the messages? Where do mailboxes or buffers come into this? How do I reference them?
Question 2: Presumably I need to filter the messages and pass them to a variable and select the data bytes I'm interested in.
Question 3: What are frameHandler, GeneralHandler and exampleClass in laymans terms.
Finally, a simple explanation of the interrupt and polling process would be appreciated so that I can start researching that element.
Any help to get me started would be appreciated.
