Basic Increment and Decrement [Solved]
Basically, I’m trying to get value Y to increment to 180 and then decrement to 0 repeatedly.
0-180 180-0 0-180…
I had an idea of using sin(x) = y. And then X++ increments.
I’m having trouble coding this, Heres what I Have.
int x = 0;
int y = 0;
  Serial.begin(9400);
  x++;
  if (x >= 180)
    x = 0;
  y = sin(x);
  Serial.println(y);
If i can get the sin working I will multiply “y” by a factor to get my 0-180.
I know on the reference page it says serial.println does not support floats but the Serial won’t even print “1” when x = 90.
All i get is never ending zeros as the value of y.
Is there perhaps something wrong in the code?
Is there a different way to approach the solution?
This seems very basic :smiley: im just not getting it ::slight_smile:
If sin worked, the increment would not be linear. Does that matter?
If all you want is for Y to change uniformly, create an int, delta. Set it to +1.
if(delta > 0)
   y++;
   if(y > 180)
       y = 0;
       delta = -1;
   y--;
   if(y < 0)
       y = 0;
       delta = 1;
If you're going to use sin(), you really need to use floating point numbers. Even if sin(90) returned 0.9999912, your program would print 0.
Also, the argument to sin() is a value in radians!
Genius Paul!
I never thought of using something sort of like a switch
(changing +1 to -1)
Thanks! This helps me in accelerating and decelerating my servo.
Final code:
int delta = 1;
int y = 0;
  Serial.begin(1200);
if(delta > 0)
   y++;
   if(y >= 180)
       delta = -1;
   y--;
   if(y <= 0)
       delta = 1;
Serial.println(y);
*********************** Problems Solved *********************
