I want to start this post by saying that I am completely new to Arduino and C/C++.
I'm trying to code a simple counter using pushbuttons and a 16x2 LCD. However, when the code is run, the counter just alternates between 1 and 0. Can anyone help me diagnose and fix the problem?
zenith5720:
Nope. Even if I do replace it with INPUT_PULLUP, the problem persists.
That might mean that both of your input pins are shorted to Ground. Try disconnecting one of the pins to see if that stops the number from going 0 1 0 1 0 1 0 1
I'm not sure what "life" is but it is obviously defined somewhere or your sketch would not compile.
I put "Life" because it was for a life counter for Magic The Gathering. I edited it out for "counter" to make you better understand it. In the original code every "counter" was replaced with "life" so it's not that that's the issue.
The issue still persists. If it helps, im using an Arduino simulator (Tinkercad, to be exact).
zenith5720:
Make me better understand it....Really? It reads like incomprehensible nonsense.
zenith5720:
Ok...
However in both occasions where you have listed code (your original post and reply #7) you do not print out the content of the variable "counter" but you do print out the content of the variable "life" (note lower case l). You are printing the word Counter.
loop function from original post:-
if(digitalRead(8) == LOW) {
counter = counter + 1;
lcd.clear();
lcd.setCursor(0,1);
lcd.print(life); // <-- prints the value of life (lower case l)
lcd.setCursor(0,0);
lcd.print("Counter");
delay(200);
if(digitalRead(13) == LOW) {
counter = counter - 1;
lcd.clear();
lcd.setCursor(0,1);
lcd.setCursor(0,0);
delay(200);
post actual complete sketch code copied and paste red direct fromIDE, not snippets or incorrect retypes.
post a circuit diagram of how you have the buttons connected.
JCA34F:
Now, @pcbbc, you know noobs always connect their buttons to Vcc, so INPUT_PULLUP is usless, unless the button is connected to GND.
Yes, but the code is expecting LOW for button pressed.
And as input PULL-UP didn’t fix it we must assume the button is actually pulled low somehow.
Perhaps the OP has buttons to Vcc and strong external pull downs, but that seems a bit much to expect...
Although as we’ve actually to see the actual code being run (just snippets and re-typings so far) it really is impossible to help.
Just wondering...
Did you want to count negative numbers?
Did you want the built in LED to show when you count down?
On a real UNO, a stripped down version of your code works.
(using serial printer, print counter, INPUT_PULLUP, jumper wire for switch to GND)
