Basic LED multiplex question
I have manually wired up a 6x8 LED matrix, multiplex style, and I have just begun testing it with a quick little program. I set one column(cathodes) LOW, and looped through the rows(anodes) turning them HIGH one at a time. That worked perfectly, but now I want to start moving horizontally and realized I don't know how to set the columns to OFF.
I know setting them LOW pulls the current and completes a circuit if the corresponding ROW is high, but what do I set the column to if I don't want it to light? As far as I know, you can only do LOW and HIGH, and it seems like HIGH would probably be a bad idea.
I've been searching through the forums and whatever programs I could find for the answer, but I haven't been able to find it. Probably too basic :slight_smile:
Whats wrong with setting them to high? the alternative is setting the other pins to be high impedance, find something about "charlieplexing" for that
Wouldn't setting the cathode and anode to +5v simultaneously damage the lights or the board?
no
