I'm just learning to work with the arduino's digital outputs to control a motor... And I'm absolutely useless with it! I'm trying to just perform the equivalent of "Hello World." I just want to be able to control the motor, turn it on or off, via code.
My current hypothesis: LED Blink with a motor instead of an LED.
The motor runs from the 5V pin, and the digital pins are 5V too (I think), so if I substitute the LED for the motor it should run.
Result: Nothing happens.
Where did my experiment go wrong? Are the pins not 5V? I've tried pins 13 through 10 and none work.
Thanks for any kind of response I can get! ![]()
--Oliver
