I'm brand new to Arduino and looking to make a specific sort of timer-based controller to push a physical button at specific times of day. Touch screen will be a cool way to set it and get feedback
At a glance, it seems like my shopping list is this:
I'm also 3d printing a thing to use the servos to drive the shaft which pushes the button... we can ignore that part for now.
Here's my questions:
What kind of wire do I get to extend from the breadboard to the servo(s) so that they can sit at a distance away from it? Preferably something from that same site (I'm in Israel)
Does the MB102 power both the Arduino and the servos?
If so - is it safe to just slap everything on the breadboard, or should the servers be connected to the MB102 from the pins somehow (not sure if it even does that...)
If not - am I correct that I'd wire the servos through the breadboard, and then have some other power supply like this 9V converter and keep the arduino totally separate?
Copper.
The diameter of the wire hardly matters, since the control pin carries almost no current, and the ground wire only needs to carry that amount of current back. The power supply for the servo will be near the servo, so the wires that comes on the servo should easily reach the power supply.
You are the one designing the system. You need to answer that question. We could help with "Can the MB102...". The answer to that is yes.
No. It is never safe to slap things together. Pay attention and work carefully. Less smoke gets lost that way.
