Hi guys,
I'm new into Arduino and I am currently facing the first struggles with the code .
Well, I plugged an rgb led to a broadboard and I'm trying to figure out what's the function of the highlighted code in the code below. I don't know what it does. Could you be so kind to explain me its specific chore and wether it's compulsory to include it?
// Define Pins
#define BLUE 3
#define GREEN 5
#define RED 6
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
digitalWrite(RED, HIGH);
digitalWrite(GREEN, HIGH);
digitalWrite(BLUE, HIGH);
// define variables
int redValue;
int greenValue;
int blueValue;
// main loop
#define delayTime 5// fading time between colors
redValue = 255;// choose a value between 1 and 255 to change the color.
greenValue = 0;
blueValue = 0;
// this is unnecessary as we've either turned on RED in SETUP
// or in the previous loop ... regardless, this turns RED off
// analogWrite(RED, 0);
// delay(1000);
for(int i = 0; i < 255; i += 1) // fades out red bring green full when i=255
redValue -= 1;
greenValue += 1;
// The following was reversed, counting in the wrong directions
// analogWrite(RED, 255 - redValue);
// analogWrite(GREEN, 255 - greenValue);
analogWrite(RED, redValue);
analogWrite(GREEN, greenValue);
delay(delayTime);
redValue = 0;
greenValue = 255;
blueValue = 0;
for(int i = 0; i < 255; i += 1) // fades out green bring blue full when i=255
greenValue -= 1;
blueValue += 1;
// analogWrite(BLUE, 255 - blueValue);
analogWrite(BLUE, blueValue);
delay(delayTime);
redValue = 0;
greenValue = 0;
blueValue = 255;
for(int i = 0; i < 255; i += 1) // fades out blue bring red full when i=255
// The following code has been rearranged to match the other two similar sections
blueValue -= 1;
redValue += 1;
delay(delayTime);
Thank you very much for your time!
Ivan V.
