I understand the Canon Powershot G12 cameras have shutter control through a basic mini stereo plug (3.5mm I think).
My question(s) is, has anyone tried this (I am sure), and it seems like a basic switch… but what volts should be sent to the camera thru the Arduino, and what pins are used, etc? Seems like a basic sketch would work.
Thanks for the link. I checked that out before, but I am not that experienced in Arduino yet
I seen another article where you can simply use a basic off/on switch, thru the pins, thru a 3.5mm cable, similar to the unit Canon sells. Just not sure of the volts to send, and how long to pulse it etc...
Anyone else out there can help really quick? thanks
According the your link the external remote works on the G12 and EOS DSLRs so you google 'Canon remote shutter pinout' and find something like www.doc-diy.net :: camera remote release pinout list which tells you that the camera expects 2 switches at the end of the cable.
You could probably do it with transistors instead of mechanical switches if you use a multimeter to determine the voltage on the 'focus' and 'shutter' wires.
Do not connect these wires directly into an arduino or any other microcontroller.
