Basic Stopwatch Project
Hi, I seem to have difficulties in creating my "Stopwatch Project" wherein I use 2 buttons to start and stop the clock from running. It counts in seconds and the only way that I can actually start it is by holding the start button, then it counts. Now what I wanted to create was a stopwatch that doesn't need the user to hold the button in order to keep it from running. I want to ask how can I make it run after just one push of a button automatically?
Here is my code:
# include <LiquidCrystal_I2C.h>
# include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Stopwatch Variables
int timer = 0;
int counter = 0;
  lcd.init();
  lcd.clear();
  lcd.backlight();
  pinMode(9, INPUT);
  pinMode(8, INPUT);
  if (digitalRead(9) == HIGH)
    counter += 10;
    delay(10);
    if (counter == 400)
      counter = 0;
      timer += 1;
    lcd.setCursor(0, 0);
    lcd.print(timer);
    lcd.setCursor(0, 1);
    lcd.print("Seconds");
  if (digitalRead(8) == HIGH)
    counter = 0;
    timer = 0;
    lcd.clear();
I can see the counter starts increasing when Pin#9 is high. If you want to make the increment independent of the button press, I think you have to write the codes for counter increment outside the conditional loop.
Hello beginnerz
Here is a recipe as pseudo code for programming in your project.
  1. Debounce the keys
  2. when the start button has been pressed, then start the timer.
  3. when the start button has been pressed, then stop the timer.
  4. if the reset button has been pressed, then reset the counters.
  5. when the timer is running, display the counter on the LCD.
Have a nice day and enjoy programming in C++ and learning.
MIND THE GAP
You need to use a new variable to know if the stopwatch is running.
bool running = false;
A bool variable can only have one of two values; true or false.
Then you can say
if (running)
    counter += 10;
    delay(10);
Next, you have to change the variable between true and false when the appropriate button is pressed.
when the stop button has been pressed, then stop the timer.
If you do all of
then what need is there for
Switch bounce could cause the stopwatch to immediately stop after starting, maybe more than once.
Not if the start button and stop button are two separate buttons.
Maybe my stopwatch example will help:
//  Stopwatch Example
//  Written by: John Wasser
const byte StartButtonPin = A1;  // Button wired from pin to GND
const byte StopResetButtonPin = A2; // Button wired from pin to GND
bool StartButtonWasPressed = false;
bool StopResetButtonWasPressed = false;
unsigned long DebounceTimer = 0;
const unsigned DebounceTime = 10;
bool IsRunning = false;
unsigned long ElapsedTime = 0;
unsigned long LastStartTime = 0;
static void ShowTheTime()
  static unsigned long lastDisplayTime = 0;
  unsigned long displayTime = ElapsedTime;
  if (IsRunning)
    displayTime += millis() - LastStartTime;
  if (displayTime != lastDisplayTime)
    lastDisplayTime = displayTime;
    // This is where you would put your code to display the time
    Serial.println(displayTime / 1000.0, 3);
  delay(200);
  pinMode(StartButtonPin, INPUT_PULLUP);
  pinMode(StopResetButtonPin, INPUT_PULLUP);
  unsigned long currentTime = millis();
  bool startButtonIsPressed = digitalRead(StartButtonPin) == LOW;
  bool stopResetButtonIsPressed = digitalRead(StopResetButtonPin) == LOW;
  // State Change Detection and debounce
  if (startButtonIsPressed != StartButtonWasPressed &&
      currentTime - DebounceTimer > DebounceTime)
    // Button has changed state
    StartButtonWasPressed = startButtonIsPressed;
    DebounceTimer = currentTime;
    if (startButtonIsPressed)
      // Just Pressed START
      if (!IsRunning)
        // Starting/Restarting the timer
        LastStartTime = currentTime;
        IsRunning = true;
        Serial.println("Started");
        // Pausing the timer
        IsRunning = false; // Paused
        ElapsedTime += currentTime - LastStartTime;
        Serial.println("Paused");
  if (stopResetButtonIsPressed != StopResetButtonWasPressed &&
    StopResetButtonWasPressed = stopResetButtonIsPressed;
    if (stopResetButtonIsPressed)
      // Just Pressed STOP/RESET
      if (IsRunning)
        Serial.println("Stopped");
        // Was not running so reset everything
        ElapsedTime = 0;
        IsRunning = false;
        Serial.println("Reset");
  ShowTheTime();
Hello beginnerz
Here comes a simple sketch coded in class-less OOP wrt my a.m. receipe.
# include <Wire.h>
unsigned long timer = 0;
int counter = 0;
enum {Start, Reset};
struct BUTTON
  int ident;
  byte pin;
  int stateOld;
  unsigned long stamp;
  unsigned long duration;
BUTTON buttons[]
  {Start, A0, false, 0, 20},
  {Reset, A1, false, 0, 20},
void ShowTheTime()
  lcd.print(timer / 1000.0, 1);
  lcd.init();
  lcd.clear();
  lcd.backlight();
  for (auto button_: buttons) pinMode(button_.pin, INPUT_PULLUP); // Button wired from pin to GND
  static unsigned long stamp;
  const unsigned long duration = 100;
  static bool startStop = true;
      counter += 10;
      delay(10);
      if (counter == 400)
        counter = 0;
        timer += 1;
      lcd.print(timer);
      counter = 0;
      timer = 0;
      lcd.clear();
  for (auto & button_: buttons)
    if (currentTime - button_.stamp >= button_.duration)
      button_.stamp = currentTime;
      int stateNew = !digitalRead(button_.pin);
      if (button_.stateOld != stateNew)
        button_.stateOld = stateNew;
        if (stateNew)
          switch (button_.ident)
            case Start:
              startStop = !startStop;
            case Reset:
              timer = 0;
              lcd.clear();
              ShowTheTime();
  if (currentTime - stamp >= duration && startStop)
    timer += duration;
    ShowTheTime();
MIND THE GAP
