Basic String/Char Question
I am coding an RFID device, and I want the device ID recorded (char tagID) in a swipe to be stored in a separate place (char safeID).
I am using global variables for both. When I compile, I get the following error:
In function 'void loop()':
error: invalid array assignment At global scope:
The global declarations:
#define tagLength 10
char tagID[tagLength];
int tagIndex = 0;
int tagComplete =
false;
//consistent values
char safeID[tagLength];
and this is where I set them equal in my loop structure:
void loop(){
while (locked == 0) // the loop to run while it waits for a bike
if (Serial.available() > 0)
readByte();
if(tagComplete == true)
//Serial.println(tagID); //Only used for PC Comm
locked = 1; //set global locked var to 1
** safeID = tagID; //set the safeID to the current TagID**
LockThat();//lock the device
Wonder what I am doing wrong?
Thank you!
Steve
You can't assign one array to another.
You need to set up a for loop to copy the array elements one by one.
Ah thats right now I remember. I'll use a for loop, thanks!
You could use "memcpy":
memcpy (safeID, tagID, sizeof (safeID));
