Basic variable declaration issue
Compiler is giving me a " 'delayPeriod' was not declared in this scope" error message. I thought I was supposed to initialize variables, esp. constants, in the setup section. I feel like I missing something huge here.
// Define input pins
const int lhInput = 1;
const int rhInput = 2;
// Turn all 7-seg display7 to output
for(int i = 4; i <= 12; i++){
pinMode(i, OUTPUT);
// RH switch
pinMode(rhInput, INPUT);
// LH switch
pinMode(lhInput, INPUT);
// delay and # of LED pulses
int delayPeriod = 250;
int pulses = 6;
// switch-state variables, initialized to false (no button presses)
boolean lhState = LOW;
boolean rhState = LOW;
// read switch state
if(digitalRead(1) == HIGH && digitalRead(2) == LOW){
lhBlink(delayPeriod, pulses);
else{
digitalWrite(8, HIGH);
delay(delayPeriod*5);
digitalWrite(8, LOW);
delay(delayPeriod);
void lhBlink(int delayPeriod, int pulses){
for(int i = 0; i <= pulses; i++){
//int x = 4;
//x++;
delay(delayPeriod);
delay(delayPeriod);
Variables declared inside setup() are not visible outside setup(). Study variable scope.
In C variables are only valid in the scope they were declared in. Have a look at the example and play with it a bit. Print the values, so you can understand the differences.
int globalVariable = 0;
int localVariable1 = 0;
localVariable1++; // this is valid
localVariable2++; // this is not valid
globalVariable++;  // this is valid too
// i is only valid inside the for loop
i++; // not valid, i no longer exists
int localVariable2 = 0;
static int staticVariable = 0;
localVariable1++; // this is not valid
localVariable2++; // this is valid, but variable will be deleted every time loop finishes
staticVariable++;  // this is valid, but variable keeps value from loop to loop
The setup function is for code you only want to run once at the beginning.
The loop is called over and over again.
They are still simple C functions and variables/objects you need in both need to be global.
A tutorial on scope.
Had a feeling it was something that basic. It could've been really easy to be snarky about it, but you guys offered something constructive. Really appreciate it. Nice community.
