Basics of WiFi Bee - Setting up
Arduino UNO (could switch to MEGA if needed) WiFi Bee - http://www.tinyosshop.com/index.php?route=product/product&product_id=650&filter_name=wifibee WiFi Shield - http://www.tinyosshop.com/index.php?route=product/product&product_id=681 Blynk Software - http://www.blynk.cc/
My current setup has a 16,2 LCD, and thermistor. These worked perfectly before installing the WiFi hardware.
I purchased the Bee a few months ago, and just got around to trying it out. I tried to use Blynk to communicate between iphone and arduino, but Blynk just says the arduino uno is offline. So, I need to troubleshoot the Bee a little more.
I can't seem to find a decent tutorial on setting up and configuring for the WiFi Bee. Is there anything out there? Could the pins for the WiFi be interfering with the LCD pins? What Library should I be using for the WiFi?
This is my first run at any wifi setup, so I'm sure I'm missing something simple...
Thanks, jason
Possibly. We can't see what pins your LCD uses.
Good question. Did you google RN-XV?
PaulS: Possibly. We can't see what pins your LCD uses.
Sorry...
LiquidCrystal lcd(6, 9, 7, 4, 8, 2);
Obviously I tried moving things around. The LCD works as long as the wifi module isn't functional in the code.
PaulS: Good question. Did you google RN-XV?
Just did, and found some great links. Thanks for the suggestion... will try some stuff shortly...
