batman-adv on arduino-yun
hello i am trying to use batman adv on two arduino yun V2 devices where i did everything as said in:
http://www.radiusdesk.com/old_wiki/technical_discussions/batman_basic
after i configure all these on both of them i connect ethernet cable to node1 and create bridge LAN with WAN to get internet from cable(WAN). also i disabled dhcp server of LAN so that i get ip address from ethernet(wan:router is present on other side) which node 1 gets. but node 2 which i can ping using batctl ping but can't get ip from router through node1. what might be the problem?
can anyone please help?
config files of node1 and node2
node 1
/etc/config/wireless
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option hwmode '11g'
option path 'platform/ar933x_wmac'
option htmode 'HT40'
option txpower '18'
config wifi-iface
option device 'radio0'
option mode 'ap'
option encryption 'none'
option ssid 'arduino1'
option network 'lan wan'
config wifi-iface 'wmesh'
option ifname 'adhoc0'
option network 'mesh'
option mode 'adhoc'
option ssid 'mesh'
option bssid '02:CA:FE:CA:CA:40'
/etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd3c:e0d9:3614::/48'
config interface 'lan'
option type 'bridge'
option force_link '1'
option netmask '255.255.255.0'
option ip6assign '60'
option _orig_ifname 'wlan0 bat0'
option ipaddr '192.168.100.25'
config interface 'mesh'
option mtu '1532'
option proto 'batadv'
option mesh 'bat0'
config interface 'wan'
option proto 'dhcp'
option _orig_ifname 'eth1'
option _orig_bridge 'false'
option macaddr 'A8:40:41:11:EB:AC'
option ifname 'eth1'
node2
option channel '11'
option hwmode '11g'
option txpower '18'
config wifi-iface
option mode 'ap'
option ssid 'Arduino2'
option network 'mb'
option mode 'adhoc'
option ssid 'mesh'
/etc/config/network
option ifname 'lo'
option _orig_ifname 'wlan0'
option ipaddr '192.168.100.6'
option mtu '1532'
option mesh 'bat0'
config interface 'mb'
option ifname 'bat0'
option ipaddr '192.168.100.26'
option proto 'dhcp'
option macaddr 'A8:40:41:12:27:88'
in /etc/config/wireless
remove
type
option ifname 'eth0 bat0' (for node 1. Remember bat0 only for node 1)
option ifname 'eth0' (for node 2)
in /etc/config/network
make ipaddr of interface 'lan' and 'mb' in different subnet for node 2 (since ipaddr of node1 is 192.168.100.25 so ip addr of interface mb in node will be in same subnet 192.168.100.X whereas ipaddr of interface lan should be in different subnet 192.168.A(any except 100).B then follow same process for other nodes.
Thanks for following up and posting the solution you had found. I'm sorry nobody replied to your first request, but I guess nobody has run into your problem and had any help to offer.
But now that you've posted your solution, maybe it will help the next person who has this difficulty.
