Hi! Noob to circuit design and Arduino so I’m drinking from a firehose - please bear with me if this question is silly. Thanks
I’m working on a project currently where I can some output being displayed on an ILI9341 from an ESP32. The device is intended to be portable and so the plan is to use a battery pack as the power supply. In order to optimize battery life, I was planning on using a switch of sorts to isolate the battery supply. What method is best to achieve this? A tactile button and a code to toggle a relay? Or are there recommendations for a switch I can use so I don’t have to code a toggled relay? Thanks for your kind suggestions.
