I need help in building my robot. I am using an arduino leonardo and an adafruit motor shield v2. I am also putting in an ultrasonic sensor. I am planning to make it small, so i am using the zumo chassis. That means it will function with the two micro metal gearmotors (also known as n20 gearmotors).
The zumo chassis has a place for putting 4 AA batteries. I want to recharge the batteries, and putting rechargeables means that i will only have 4.8v. But my project requires at least 6v. I need to power the two motors, the ultrasonic sensor, the arduino and the motor shield. So i will be needing a lot of current. At the same time, i need to fit the battery in the battery compartment of the zumo chassis.
Which battery should i use?
Should i use two li ion cells (thats about 7.4v and 2600mah)?
If i use alkalines, will it work?
Please help
