Batteries
Hello! I hope this is the correct section. Any how, I have been having some trouble figuring this out and I thought someone here could help me. My local Shopko has some cordless phone batteries on clearance for a great price. They are 3.6v NiMH, but I don't know how to charge them since I don't have a phone that uses that particular battery, but I have a phone that uses a slightly different 3.6v NiMH. The only difference is the mAh and the connector. Can I make an adapter for the connectors and use the phone to charge the battery? Or is that not a good idea? If it matters, the clearance one has less mAh.
Thanks for any help! E
Yes, absolutely.
Great! They should make an awsome source of power.
The phone isn't accepting the battery for some reason. I think it might just be too old and dead. Would you, by chance, know any other ways of charging a 3.6v 800mAh NiMH battery? I have not been able to find any chargers that suit my needs.
Thanks! E
Obtain a sample from maxim-ic.com and make your own charger
http://www.maxim-ic.com/datasheet/index.mvp/id/4788 http://www.maxim-ic.com/datasheet/index.mvp/id/1471
http://para.maxim-ic.com/en/search.mvp?fam=batt_chrg&tree=powersupplies
I'd upgrade to Li batteries, charge circuits are much simpler see max1811 for example
Only drawback is dealing with surface mount parts. Takes a good eye steady hand, and solder flux.
