Is it better to power the Arduino board with a 3v battery than a 9v? What about 1.5v?
How do I connect a battery directly to a servo without using a bread board?
Will there be power loss if I use a 6 ft extension USB cable to plug the Arduino into the computer?
Different "Arduino" uses different voltage. Specify controller!
How to connect? Nobody can tell as You don't provide links to datasheets, nor pictures.
6 feet USB cable is good to supply a controller.
Arduino Uno. All the pictures is of a 9v battery plugged into the Arduino Uno, but the Arduino is 5v. Would 3v be better?
