I have had many electric drills which i have skipped due to the non availability of replacement battery packs.
Many of my aquaintence have the same problem and im sure many would like a solution.
Please do not suggest dewalt as they are just too expensive for most of us.
I can get replacement cells of the lithium phosphate type but they require spot welding.
I can get lipo cells with solder tags however.
Some packs i have dismantled have very poor proection circuits, for instance one five cel pack had two in series and 3 in series with some sort of protection ccircuit.
Both lithium phosphate and lipo cells should ideally have indvidual protection and individual cell balancing when charging.
Without this cell longevity is drasticly reduced and in the case of lipo can be dangerous.
Individual protection circuits and individual protection and charging circuits can be had but are expensive when considering multicell packs.
I would like to build a micro based solution as nanos can be had for about 3 bucks so a custom board may do it.
However unit will need to be permanently connected to battery and needss to be put to sleep when not in use, battery would be about 1200 mA H.
How do i wake up and put to sleep though ?
Any other thoughts ?
Am i missing something blindingly obvious ?
