Battery connect
How can I properly connect the lithium ion battery to the Adruino. Would it be through soldering or using female header pin and in gnd and 5v pins on arduino?
Never solder a battery directly, they can blow up. Always use connectors.
Ok thank you, so just connecting the female headers to batter connectors will be just fine? :o
How can I properly connect the lithium ion battery to the Adruino. Would it be through soldering or using female header pin and in gnd and 9v pins on arduino?
What voltage battery?
