After adding the currents of each components together, the whole current is: 120mA
The below image is the measurement that I have done with multimeter, which is: 13.5mA
Why there is a huge difference between these two numbers?
More info:
Same result (13.5) with another multimeter has shown.
If I change that rotatory-thing in the middle to "20m", the circuit would have some unusual activities.
So you are connecting your DMM Incorrectly, as in your post, and you get 170 'things' (I assume mA) - does this look correct based on the resistor and LED Datasheet.
Great, now we need to know how you have that LED wired, what size of series resistor you have, or if it is a 'resistor less' LED (if it is we need the datasheet).
180mA is HUGH for an LED - I run them at around 5mA
