Battery Discharge
I am wondering how much faster (if at all) a battery will discharge when using a step up voltage regulator. I have circuit that draws 100 mA with an operating voltage of 5 V. Now if I power this circuit with a 5 V, 2000 mAh battery and no voltage regulator, I should have 20 hours of battery life, correct? However, I want to power my 5 V, 100 mA circuit with a 3.7 V 1000 mAh battery with a voltage regulator that will step up 3.7 V to 5 V. Will my battery life be 10 hours or significantly less than that? How do step up regulators typically affect battery life?
Thanks for any help, I am new.
akafoury:
Yup, that's right. (although the battery voltage will drop over time of course)
If the converter was perfect (i.e. it took no power itself), then you would just look at the power required:
5V * 100mA = 500mW
The 3.7V battery has to supply this same amount of power, so we can work out what current is needed to do that by:
Amps = 500mW / 3.7V = 135mA
In reality the converter will take around 10% of the power for itself, say 15mA in this case
so you would need 135 + 15 = 150mA.
so you would expect your 1000mAh 3.7 V battery to last 1000 / 150 = 6.6 hours
Yours,
TonyWilk
