Battery for Promini
Hello,
I am using Promini 3V, 8 Mhz to control a solenoid which requires 5V,1.2 Amps current.
Is it okay if I connect a battery 5V,1.2 amps to the RAW pin of the promini?
Thank you!
Yes
Yes.
You will need a MOSFET transistor or motor controller for the solenoid.
Thank you!
Should the mosfet be connected like this:
Attached is the picture.
That won't work well, if at all. Use a logic level MOSFET instead, and add a flyback diode across the coil terminals.
