battery indicator
so from the charging to the battery indicator to the battery to the project is this correct???
What are you talking about? Do you have some other topic going?
nope just brainstorming my project well part of it
So you have a battery charger and a battery. You will want to connect the battery as shown in the attached pic.
and then a wire from the bat +/- to my project and i also have a crazy idea that involves this wireless charging would i connect this to the in???
Yes, I think you could connect the wireless charger, but you will need to verify that it will work with whatever voltage you are using. You will also need to check that the charging PCB will take whatever voltage you are using.
ok so maybe some resistors or capacitors, something like that but this i newish to me so thank you for the ideas
