Battery is not powering Fio, however through USB it works fine
I'm using Fio for the first time and I've connected Fio to a 250mah 1S battery (to BAT +, -) terminals.
When I switch on the power switch, nothing happens (with or without xbee on it).
However, when I connect USB cable, CRG led lits up and also power on led glows. I want to use Fio wirelessly, so please let me know if I'm doing anything wrong or if there's a work around to fix this issue.
Thanks a lot
Was the battery charged? When you turn on the power do you get 3.3V at the 3.3V pin?
Thanks for the reply.
No, I don't get 3.3V when connected to lipo alone. I get 3.3V only when connected through USB.
I charged lipo through Fio for an hour. May be lipo is damaged(I shorted the leads for couple of secs while soldering), I will use another lipo and update if that works.
