Please see attached picture for reference.
The read voltage will go to zero for a while and then begin reading proper voltage again. I am unsure what to do about this problem. When I check battery voltage with a VM meter at the time my arduino is saying its zero it shows 3.33 volts. Why is my arduino saying the voltage is fluctuating?
//set up the sensor pin for reading the voltage
int sensorPin = A0;
//initialize serial communication
int sensorValue = 0;
//set sensorValue as an analog read of the A0 pin
sensorValue = analogRead(sensorPin);
//print the value of the sensor multiplied by 0.00326 to get a true voltage reading.
//this is a value of 0 – 1023 coming from the sensor pin and has to be converted.
Serial.println (sensorValue * 0.00326);
delay(1000); //give a delay between readings.
Looks like a bad connection.
How is the analog input connected to the battery?
Indeed! Bad connection to Arduino ground. Thank you.
Also, I had some math wrong! Instead of multiplying by 0.00326 it should have been 0.00951.
int sensorPin = 0; //set up the sensor pin for reading the voltage
int sensorValue = 0; //variable to store the value coming from the sensor
//This is the default value, but we can set it anyways
analogReference(DEFAULT); //5V Reference on UNO
Serial.begin(9600); //initialize serial communication
sensorValue = analogRead(sensorPin); //set sensorValue and an analog read of the A0 pin
//print the value of the sensor multiplied by 0.00951 to get true voltage reading.
//this is a value of 0 - 1023 coming from the sensor pin and has to be converted.
Serial.println("Battery Voltage Is");
Serial.println(sensorValue * 0.00951);
