A little out of my exposure here.. Normally I have just run with straight battery packs or directly from +5v USB ports (power bricks..etc)
I'm not sure what the answer is.. or what is the best search terms here?
But if I wanted to power a project from a battery pack.. UNTIL a usb cable was plugged in.. how would I go about looking into that?
Initial thoughts:
do I use rechargable batteries then? (not sure if I want to just charge, was originally just thinking about an ALT power option/source (no re-charging of anything?)
some sort of way to detect the usb cable was connected right? and then somehow use that source instead of the batter pack?
Not sure how to go about detection? Perhaps there is a little board out there that people use for this or something?
I have in the past created projects that use rechargable Li-Ion batteries.. with a recharge port.. but that is also used a kill switch to cut the project and charge the battery packs..
you needed your own charger
not usb related at all
didnt power the project up, was purely to recharge the battery pack installed inside project.
The Arduino UNO R3 has an automatic switch. If the voltage at the Vin pin is greater than 6.6V, the USB power is disconnected. If you disconnect the voltage to Vin, it switches to USB power.
There is a diode between the power jack and the Vin pin so the switchover voltage is more like 7.2V at the power plug.
hey i know this is off topic but i saw that you in a volpins props daft punk helmet thread and i was hoping you had the code for that and what arduino you used. i wanted to know this because i really wanted to do this and i really dont want to make new code mainly because i dont know how to code. could you send me a message when you can? if you dont have the code that's fine ill just need some help with coding because im not a code guy. I mainly do CAD
