Battery powered arduino and load
Hi guys, I wanted to power my arduino and load continuously using solar panel and lithium ion battery setup. I was looking at lithium ion battery charger tp 4056 and found this to not be suitable for high mah batteries like 8000 mah that i am going to use. I humbly request the team to suggest a good charger for 8000 mah lithium ion battery.
While waiting You can also try Oncle Google on "solar charger 10000 mAh".
You also need to be careful to select a charger that will allow you have a load connected to the battery at the same time
Also divide the output claims of the solar panel by 2 or 3 to get a more realistic value. They are very optimistic in the specs (lies?).
Yes did that
