Hello everyone, I searched the internet for a circuit but I can't find it very clearly. It is most likely very easy. I am doing a project where an Arduino nano is battery powered through the pins and not the main port, and it works perfectly, but the problem is that I should create a circuit that allows me to charge the battery and at the same time continue to use the Arduino. Let's say I would like to do just like a cellphone, that even if it is charging, I can continue to use it. Is there an Arduino module? Thanks
Have you searched for "lithium backpack arduino"?
I searched this but I found a lot modules that i don't think that are what im searching. Like this from adafruit or this or this
Hi, ok i understood. But can I recharge and at the same time use arduino with this battery? It should work without problem because the corrent exit the battery anyway, correct?
Yes, I have arduino pluged on +OUT and -OUT and a charger (mobil charger),
pluged on USB together.
+OUT and -OUT has about 4,3 V on charger and 3,7V if no charger.
RV minirin
Ok thanks
