I am designing an adjustable PSU and i would like to know what you think.
Specifications:
-2 channels capable of delivering 0-12V/0-1A(the channels are not isolated in this version)
-li-ion battery pack(up to 4s5p 18650 cells) with an aproximate autonomy of 6h at full output power
-graphic LCD(128x64px) with 0.5x0.5mm pixel size
-capacitive buttons(PCB traces)
-can be mounted on DIN Rail
I use an ATMega2560 with arduino bootloader and it will also have an expansion header for addon modules(memory, comunication, output expansion, multiple units sincronization and more).
I attached the front panel, it will be as in pdf(white soldermask with black silkscreen) and the LCD is also COG FSTN(Black on White) to fit with the front panel and the white plastic case.
Just let me know what you think or if you need other informations.
Have a nice day,
Andrei.
DPS21201_Front_Panel.pdf (25.6 KB)
