Battery powered WS2812B problem
Hello friends !
I want to make a project with 2 meters of 5V WS2812B led strip.
(60 chip / meter)
4 rows of leds, each 50cm.
I will not use Arduino, I will only use a controller.
But I do not know what kind of battery to use.
(The brightness of the LEDs is important to me because it will be a video light.)
Powerbank, 18650, AA battery or rechargeable AA battery. Which one should I choose ?
I will not use white light mostly. I will use colors such as yellow, orange and pink other than red, green and blue. There will be no animation.
It should not be discharged for 60-90 minutes.
Please help.
Then you are in the wrong forum!
missdrew:
this is just a simple demo, no need to be this harsh. If I can achieve this I will continue with arduiono.
How was I harsh? I pointed out that you are in an Arduino forum,
This is the section you are in.
I can give you a clue : Measure the current consumption (That no one other than YOU can measure) and use that to work out what supply you need.
OK, 120 LEDs at 55 mA if full white (and likely to be so on one occasion or another). 6.6 Amps. For 1½ hours that is 10 Ah.
You want a proper 5 V. Find a battery pack of around 12 V with a charger - could be a 3S LiPo or a SLA, rated about 10 AH, and a switchmode "buck" regulator rated 10 Amps (output). It will require only half that current on the input side but you want to generously over-rate the battery especially for a 1(½) hour discharge.
mrjoeblack:
Are you suggesting that if you fail this non-Arduino project, you will eschew Arduinox (or "arduiono"s) just on principle?
What controller is this then?
