Battery question based on jump starting a car
Apologies if this is off topic, but I have a query about batteries/power sources and hoping to learn more.
I was thinking about jump starting a car with a flat battery, using another car. The advice online about the order to connect negative and power jump leads varies wildy.
Can anyone explain how you should connect two batteries in this scenario (e.g 4 steps for each end of 2 jump leads), more important can you explain from an electronics/power persepctive, why?
Basically the connection order doesn't matter from an electrical point of view. It is just a matter of safety whether a half connected lead will short against anything, like the chassis of the car or the other half connected lead.
Moved your post to a better category.
From where I was taught, many years ago.
  1. Connect the positive of the good battery to the positive of the flat battery.
  2. Connect the negative of the good battery to the motor gnd, not the battery terminal, of the flat battery vehicle.
The reason is you are trying to START the car, so the best and safest connections to the starter are battery positive and motor ground.
Tom.. :smiley: :+1: :coffee: :australia:
I would modify that ever so slightly to add that it assumes the negative of the battery is connected to the car chassis. That is probably true for all modern cars but I think there are some vintage cars with the positive connected to the chassis. In that case be really careful because the chassis of one car will probably be negative ground and the other positive ground.
Those are extremely rare. (i've never come across one)
There i disagree. Usually the jumper leads are not quite thick enough to provide the current required to kink the starter-motor over, and on modern cars, many times there are pother electrics (or electronics) that require power as well. and the battery GND is normally connected to the chassis via a thick enough cable.
What i do is a follows :
  • I start the engine of the car with the good battery (or leave it running)
  • I connect the GND and the power cables between vehicles, one cable at a time, making sure i do not have two connected cables in hand at the same time. This is also important when disconnecting the cables !! The idea about connecting the power cable first is that while connecting it on the car with the flat battery is that if you then accidentally touch the chassis, you can not cause a short with the power cable (through an already connected GND).
  • I Rev the engine of the car with the good battery for about a minute or 2 at about 2000 - 3000 revs (depending a bit on the engine type, diesels rev less). The idea is to charge the flat battery sufficiently to make sure that it is at least not draining the system and it will actually provide some power. (it actually does normally, unless the battery is actually broken, in which case is should anyway be replaced)
  • Then i go through the normal starting procedure, again while revving the engine of the car with the good battery.
  • Then i remove the cables from both cars, again one by one, and ideally the GND cable first.
I agree. Maybe the OP is a vintage car enthusiast and has one, we do not know. Maybe someone else finding this has such a car.
The only hassle there is, having the donor car engine running, if the flat car has an electrical fault and it pulls your expensive alternator down with the problem car.
ALL breakdown services have jumper batteries for this reason, not just for portability.
Tom... :smiley: :+1: :coffee: :australia:
And one benefit of a jumper pack is that if you accidentally connect the leads backwards, it'll warn you.
Ask me how I know :wink:
Thanks @Grumpy_Mike and thanks for moving to a better category.
Thank you all so much, pleasantly surprised by the number and speed of replies.
I'm suffering from Covid at the moment, so online intermittently.
I'll wait a few hours (or tomorrow) morning for any more replies; then I'll try to take it all in and summarise.
Really appreciate it, thank you all.
Is that really so ? I am not convinced there. An alternator generates a maximum current, but does shorting it out actually burn it, or does that just drop the voltage down ? as said i am not sure either way, but Alternators tend to give way due to overheating (insufficient ventilation) or brush wear or inverted connection.
The risk you take with not having the donor engine running is that you may flatten it's battery as well in trying to start the other car with it, and if there really is an electrical fault, discharging the donor battery very fast may cause also that to explode.
Considering these things, it is probably best to put a multimeter on the flat battery and measure the voltage.
  • 12.5v is considered 'FULL' on a Lead-acid-battery
  • 11.5v is considered 'EMPTY'
  • "Charging' between 13.5v - 14.0v (once 14v is reached the battery is full)
  • If the voltage is below about 10.5v i might not bother trying to start the car with that battery connected.
It is of course important to find out why the battery is flat, and if there is a (slow) drain on it.
I fully disconnect the battery on my oldtimer since i know the radio draws a small current even when the ignition is off. Small drains can be really bad for VMF (very much force) Lead-Acid batteries, that have thin plates to create a big surface for the chemical reaction to take place. These small drains tend to warp these plates, ruining the battery.
The reason for making the chassis connection last is that the last connection makes the spark, and you want to keep that spark away from any flammable gasses emitted by the battery.
This is very true -- if you connect the chassis side first, then if you slip while connecting the positive side, you can easily short the positive to the negative. If you do it the right way and connect the much-more-isolated/insulated positive sides first, then a slip while connecting the chassis sides will be less likely likely to accidentally short the battery.
In terms of non-automotive, electronics/power perspective, protect yourself from mistakes while making connections. For dupont connections on a breadboard, do your wiring with the power off--use switches and avoid loose hot wires.
Extending that logic to working on cars in general, it's good practice to disconnect the battery chassis lead before doing any work. I watched a neighbor light up a breaker bar while changing his plugs when he slipped and one end of the bar swung around and hit the battery positive terminal.
I've been taught to place the donor clamps on a dry surface or have someone hold them separated.
Connect to the flat battery in either order.
Connect the donor + directly to the battery.
With engine running, connect the donor - to the engine lift eyelet mounted on the engine.
Before attempting to start the vehicle in distress, turn on their headlights to verify good connection. If lights are dim, wiggle/adjust connections until headlights go bright.
Turn off headlights and wait ~ 30 seconds.
Start vehicle.
If started, remove cables and turn on headlights again to verify the alternator and charge system is working.
If the headlights are dim, they probably won't make it home or to a service center.
Hi, @2112
Do they still have lift eyelets?
All morris/austin motors used to.
Don't know why, two burly blokes could lift one out.. :grin: :laughing: :smiley:
The other side of the coin is what sort of jumper leads should you have with modern electronic motor cars?
Suppression/Surge type etc.
https://www.sparesbox.com.au/part/oex-jumper-leads-750a-w-surge-protection-2-b-and-s-weldflex-4m-acx0499?gclid=Cj0KCQiA4aacBhCUARIsAI55maH_q_0BFFctb41j_w7YMPyuSp_xR9vO1Ipcf9eHX2YM3ETZDjYl3KUaAv3OEALw_wcB
PS. Never buy jump cables under about $40, get decent ones that are properly terminated and use decent gauge cable
Actually just one. I rebuilt the engine in my Austin Healey Sprite two times! Both times I removed ALL the accessory components and picked the engine up and out. Put back the same way. I am not a really big guy, but was considerably younger!
Wow, this has grown.
Thanks all, I can't really take it in right now (Covid fuzzy head), but I can say I have some good quality leads.
I didn't expect the speed and volumes of replies, really appreciate it, but will have to take it in over the weekend once the fever dies down.
Hi, @mjbatty
How is the attention span, the first three days I had Covid, I couldn't even sit in front of the TV and concentrate on a program.
Then again there are lots of programs on these days that don't need you to concentrate. :grin: :laughing: :sleeping: :grin: :sleeping:
Tom.... :smiley: :+1: :coffee: :australia:
The safest way is use jumpstarter. No need for a person to donate his car.
