Hello
I am new to the world of Arduino. I have an idea for a project which involves connecting a Nano with a Memsic 2125 Accelerometer and an MP3 add-on board. (MP3 Player add-on for Arduino Nano) What would be the best means of powering these three boards via a battery? I initially thought a 9v but some info I've read seemed like that may not be the best method.
AWOL:
Any specifications (e.g. minimum runtime) or explanation of constraints (e.g. limited mass/volume/budget) would be appreciated.
Sorry. Minimum runtime would be 2 hours. My constraints are that the entire package needs to fit inside a block of wood with maximum dimensions of Height: 1.25", Width: 1.75", Length: 7.0". The total weight (electronics plus block of wood it will fit inside of) is 5 oz. I plan on hollowing out a large part of the inside to keep the overall weight under the 5 oz. limit.
I think that should do it. If there's any more information you require, let me know.
I haven't received any updated postings to my question so I'm wondering if it just was "buried" in the other postings since this seems to be a very active forum.
Any ideas from anyone given the constraints I'm under?
Well run time of 2 hours is part of the information needed, but without knowing what the total current consumption of all three modules one can't calculate a mAH rating answer for you. But for highest energy density per size one can't do better then a rechargeable Li-po battery pack, probably a 2 series cell pack (voltage range of 6 to 8.4 empty to full) with a Mah rating (which we can't know yet) to match your 2 hour duration requirement. They can be had in several form factors. They do require Li-Po compatible chargers but are the most cost effective/size efficient solution in the long run.
Here is a selection of possible 2 series cell lipos pack so you can get a feel for size Vs capacity Vs price. Note there are five pages of choices!
SGroner:
Thanks in advance!
You have to play your part more actively to supply more info of your project and not wait for other to answer your all question without info.
