Hi all,
I am VERY new to Arduino and electronics in general. I am trying to build a project with the following components:
- Arduino Nano
- KY-031 Shock Sensor
- 6" 5v White LED Light Strip (about 8 or 9 individual LED's)
- Bluetooth using an AT-09
Can someone guide me to figuring out the power requirements for the entire setup? I have read that the optimal setup would be to power the lights with a separate battery back and then powering on and off the lights from the Nano using a relay but I would like to avoid that. If possible, I would rather have all the components connected directly to the Nano and then control the lights by writing to the pins.
In actual usage, the light strip will not always be on. I would say that for every hour that my device is turned on, the light will be on for perhaps 15 minutes.
For the batteries, I am very unclear about how to size this. From what I understand, I need to connect my batteries to VIN/GND and then the lights would go on the 5v pin. And I also understand that I should supply between 7 and 12v of power which means I can use a single 9v battery on VIN/GND. But a 9v battery isn't ideal for LED lights so I should use 6AA instead. Is that correct?
Lastly, I've read that I need to connect the Nano to the LED strip via a MOSFET and a resistor. Is that correct?
Again, I am very new to this and appreciate any help.
Thanks for your guidance!
