battery Status command
Hello anyone know how i can print the battery status which i use on arduino for power ?
Thanks, Mifos
Not without us knowing what your battery power system might consist of.
mifos: Hello anyone know how i can print the battery status which i use on arduino for power ?
Thanks, Mifos
Need more info:
"Print" status to WHAT? Serial port? LCD display? What is "battery status"? Terminal voltage? What is your battery voltage range?
  Serial.println("Battery: OK");
When it stops printing "Battery: OK" you know the battery is flat.
LOL!
I have used this https://code.google.com/p/tinkerit/wiki/SecretVoltmeter with success to keep the brigthness of a LED constant when the battery voltage is changing (eg:using the USB or running on 2 AA batteries)
Thanks m8 that help.
deladriere: I have used this https://code.google.com/p/tinkerit/wiki/SecretVoltmeter with success to keep the brigthness of a LED constant when the battery voltage is changing (eg:using the USB or running on 2 AA batteries)
You owe me some windex.
