Just a quick question for y'all. Is there any battery that can give out lots of current? Can a rechargeable battery do just that? I have a 2 dc motor and an L298n driver project. When I tried to run it using 12v AA batteries, it will run but it will stop minutes after. But when I used 2 12v paralleled batteries, It can last longer but not too long :D Any help from you guys will be much appreciated. Btw, here's the specs of what DC motor I used.
DC Gear Motor 12V 178RPM – SGM37-3530 Gearbox: Spur Gear Rated Voltage: 12V (6 to 12V Range) Nominal voltage: 12 V Free-run at 12 V: 178 RPM Free-run current at 12 V: 120 mA Stall current at 12 V: 1.2 A Stall torque at 12 V: 8.4 kg.cm Gear ratio: 1.56 Reductor size: 24 mm Max Power: 4.8W Weight: 200g
