Baud rate affects 6 Degrees of Freedom IMU Digital Combo Board - ITG3200/ADXL345
The IMU can work perfectly if I set the baud rate at 115200, but when I change baud rate for the code and the device to 9600, the monitor only returns two or three data and stops returning any data. How I gonna solve this problem to make it work at 9600?
#include <Wire.h>
int Gyro_output[3], Accel_output[3];
float dt = 0.02;
float Gyro_cal_x, Gyro_cal_y, Gyro_cal_z, Accel_cal_x, Accel_cal_y, Accel_cal_z;
float Gyro_pitch = 0; //Initialize value
float Accel_pitch = 0; //Initial Estimate
float Predicted_pitch = 0; //Initial Estimate
float Gyro_roll = 0; //Initialize value
float Accel_roll = 0; //Initialize value
float Predicted_roll = 0; //Output of Kalman filter
float Q = 0.1; // Prediction Estimate Initial Guess
float R = 5; // Prediction Estimate Initial Guess
float P00 = 0.1; // Prediction Estimate Initial Guess
float P11 = 0.1; // Prediction Estimate Initial Guess
float P01 = 0.1; // Prediction Estimate Initial Guess
float Kk0, Kk1;
float Comp_pitch;
float Comp_roll;
unsigned long timer;
unsigned long time;
void writeTo(byte device, byte toAddress, byte val) {
  Wire.beginTransmission(device);
  Wire.write(toAddress);
  Wire.write(val);
  Wire.endTransmission();
  }// Adapted from Arduino.cc/forums for reading in sensor data
void readFrom(byte device, byte fromAddress, int num, byte result[]) {
  Wire.write(fromAddress);
  Wire.requestFrom((int)device, num);
  int i = 0;
  while(Wire.available()) {
    result[i] = Wire.read();
    i++;
void getGyroscopeReadings(int Gyro_output[]) {
  byte buffer[6];
  readFrom(0x68,0x1D,6,buffer);
  Gyro_output[0] = (((int)buffer[0]) << 8 ) | buffer[1];
  Gyro_output[1] = (((int)buffer[2]) << 8 ) | buffer[3];
  Gyro_output[2] = (((int)buffer[4]) << 8 ) | buffer[5];
void getAccelerometerReadings(int Accel_output[]) {
  byte buffer[6];
  readFrom(0x53,0x32,6,buffer);
  Accel_output[0] = (((int)buffer[1]) << 8 ) | buffer[0];
  Accel_output[1] = (((int)buffer[3]) << 8 ) | buffer[2];
  Accel_output[2] = (((int)buffer[5]) << 8 ) | buffer[4];
  int Gyro_cal_x_sample = 0;
  int Gyro_cal_y_sample = 0;
  int Gyro_cal_z_sample = 0;
  int Accel_cal_x_sample = 0;
  int Accel_cal_y_sample = 0;
  int Accel_cal_z_sample = 0;
  int i;
  delay(5);
  Wire.begin();
  Serial.begin(115200); // Registers set
  writeTo(0x53,0x31,0x09); //Set accelerometer to 11bit, +/-4g
  writeTo(0x53,0x2D,0x08); //Set accelerometer to measure mode
  writeTo(0x68,0x16,0x1A); //Set gyro +/-2000deg/sec and 100Hz Low Pass Filter
  writeTo(0x68,0x15,0x09); //Set gyro 100Hz sample rate
  Serial.print("time\tPredicted_pitch\tPredicted_roll\n");
  delay(100);
  for (i = 0; i < 100; i += 1) {
    getGyroscopeReadings(Gyro_output);
    getAccelerometerReadings(Accel_output);
    Gyro_cal_x_sample += Gyro_output[0];
    Gyro_cal_y_sample += Gyro_output[1];
    Gyro_cal_z_sample += Gyro_output[2];
    Accel_cal_x_sample += Accel_output[0];
    Accel_cal_y_sample += Accel_output[1];
    Accel_cal_z_sample += Accel_output[2];
    delay(50);
    Gyro_cal_x = Gyro_cal_x_sample / 100;
    Gyro_cal_y = Gyro_cal_y_sample / 100;
    Gyro_cal_z = Gyro_cal_z_sample / 100;
    Accel_cal_x = Accel_cal_x_sample / 100;
    Accel_cal_y = Accel_cal_y_sample / 100;
    Accel_cal_z = (Accel_cal_z_sample / 100) - 256; // Raw Accel output in z-direction is in 256 LSB/g due to gravity and must be off-set by approximately 256
  timer = millis();
  Accel_pitch = atan2((Accel_output[1] - Accel_cal_y) / 256, (Accel_output[2] - Accel_cal_z) / 256) * 180 / PI;
  Gyro_pitch = Gyro_pitch + ((Gyro_output[0] - Gyro_cal_x) / 14.375) * dt;
  //if(Gyro_pitch<180) Gyro_pitch+=360; // Keep within range of 0-180 deg to match Accelerometer output
  //if(Gyro_pitch>=180) Gyro_pitch-=360;
  Comp_pitch = Gyro_pitch;
  Predicted_pitch = Predicted_pitch + ((Gyro_output[0] - Gyro_cal_x) / 14.375) * dt; // Time Update step 1
  Accel_roll = atan2((Accel_output[0] - Accel_cal_x) / 256, (Accel_output[2] - Accel_cal_z) / 256) * 180 / PI;
  Gyro_roll = Gyro_roll - ((Gyro_output[1] - Gyro_cal_y) / 14.375) * dt;
  //if(Gyro_roll<180) Gyro_roll+=360; // Keep within range of 0-180 deg
  //if(Gyro_roll>=180) Gyro_roll-=360;
  Comp_roll = Gyro_roll;
  Predicted_roll = Predicted_roll - ((Gyro_output[1] - Gyro_cal_y) / 14.375) * dt; // Time Update step 1
  P00 += dt * (2 * P01 + dt * P11); // Projected error covariance terms from derivation result: Time Update step 2
  P01 += dt * P11; // Projected error covariance terms from derivation result: Time Update step 2
  P00 += dt * Q; // Projected error covariance terms from derivation result: Time Update step 2
  P11 += dt * Q; // Projected error covariance terms from derivation result: Time Update step 2
  Kk0 = P00 / (P00 + R); // Measurement Update step 1
  Kk1 = P01 / (P01 + R); // Measurement Update step 1
  Predicted_pitch += (Accel_pitch - Predicted_pitch) * Kk0; // Measurement Update step 2
  Predicted_roll += (Accel_roll - Predicted_roll) * Kk0; // Measurement Update step 2
  P00 *= (1 - Kk0); // Measurement Update step 3
  P01 *= (1 - Kk1); // Measurement Update step 3
  P11 -= Kk1 * P01; // Measurement Update step 3
  float alpha = 0.98;
  Comp_pitch = alpha*(Comp_pitch+Comp_pitch*dt) + (1.0 - alpha)*Accel_pitch; // Complimentary filter
  Comp_roll = alpha*(Comp_roll+Comp_roll*dt) + (1.0 - alpha)*Accel_roll; // Complimentary filter
  float angle_z = Gyro_output[2];
  time=millis();
  Serial.print(time);
  Serial.print("\t");
  Serial.print(Predicted_pitch);
  Serial.print("\t");
  Serial.print(Predicted_roll);
  Serial.print("\n");
  timer = millis() - timer;
  timer = (dt * 1000) - timer;
  delay(timer);
How about posting the code? Just a thought.
What does the value for the delay() become when you send data ssslllooowwwlllyyy?
Why do you need to send data ssslllooowwwlllyyy?
