Baud rate change slows down void loop and stepper motor speed??
And you have not understood my suggestion.
You appear to be calling serial.print() tens of 1000s of times a second (every time loop() is executed), the poor serial port is overwhelmed. Do you get that?
I have not modified the standard library apart from Serial.println(_currentPos);
That's may seem like a small one-line change but it has a lot of ramifications.
Try this
   if ((millis() % 1000) == 0)  stepper.currentPosition(); // this function retuns current stepper position over serial.println()...written in accelstepper library
That should only print the position every second (it may miss a beat every now and then). I don't know if that's the problem but it can't do any harm.
Rob
