Baud Rate Conversion to non standard (MIDI)
I've made a successful MIDI device. Now I want to make it wearable/wireless.
The problem I'm running into is Xbee's, if you tell them a non-standard baud rate, if I understand the manual correctly, they'll round up to the nearest standard.
I want to have a standard MIDI cable on the reciever end of the other Xbee.
I've done a couple of days of research and I'm seeing something about different types of asyncronous reciever/transmitters . UARTs. I'd prefer not to have to purchase the commercially made units as they're $200 a pop for baud rate converters. Something tells me they probably wont even have the 32.15k rate anyway.
Any point in the right direction would be much appreciated, including literature I might purchase.
I've got an electronics technician background so you don't have to use velvet kid gloves on me.
Anyways, thanks in advance...
Kristof
perhaps you could use a cheap boarduino (smaller arduino) as sort of a baud rate translator. set up a software serial with the xebee and use the uart to connect to the midi. at 20$ it would still be less than the commercial options.
