Baud Rate doesn't match
I have a simple program which reads an analog value and sends it to the serial port. It works, but in spite of the fact that I set the serial ports baud rate to 9600, in order to correctly display the results on the Serial Port Monitor, I must set the monitor’s baud rate to 4800.
What’s up with that?
Here’s my code:
// Potentiometer Reading Program
const int POT = 0; // Pot on analog pin 0
int val = 0; // variable to hold the analog reading from the POT
  val = analogRead( POT);
  Serial.println( val);
Processor is running at 8 MHz but you are building your sketch for a processor that is running at 16 MHz. The delay time will also be wrong.
Damn you're good!
