Baud rate off I am a little confused
little confused right now my baud rate seems off when I am monitoring.
code
void setup(){
void loop(){
Serial.println(test);
when I go to serial monitor I have to set the baud rate to 4800 if I set the baud to 9600 I get a bunch of gibberish.
If I change the baud in the code to 4800 and I have to monitor at 2400.
this is using Arduino IDE 1.0.5... I plan on switching to 1.6.1 in the near future but I have had some issues with my libraries.
IDE settings
board selected is Arduino pro mini 5V, 16mhz ATmega328
programmer selected is USBTinyISP
I am using FTDI to interface to a atmega 328P-au opperating at 5V
I am getting a compiler error:
sketch_may10a.cpp: In function 'void loop()':
sketch_may10a:5: error: 'test' was not declared in this scope
Sounds like you are running it at 8 MHz, TBH.
Serial.println("test");
Will help for a start, as Nick has said the sketch you posted won't even compile without doing the above change.
Tom.... :slight_smile:
the issue was the 8mhz...
thanks.
