BB-8 build with XBEE and Arduinos code advice needed
hello guys I have search for 3 days and tried lots of different methods but nothing has worked as of yet.
so I have two arduinos and two xbees, I need to trigger a 4 pins on Arduino 2 (BB-8) with 4 push buttons on Arduino 1 (remote). seems easy huh ??? for some reason not for me. this is my remote code and BB-8 dome code, any help is much appreciated. also I have changed my setting on my Xbee multiple times to many different configurations trying to make them communicate while on Arduino but nothing. I'm thinking its a power issue??
//this is for the remote//
int potPin1 = 1;
int potPin2 = 2;
int potPin3 = 3;
int potPin4 = 4;
int potPin5 = 5;
int button1 = 3;
int button2 = 4;
int button3 = 5;
int button4 = 6;
int val6 = 0;
int val7 = 0;
int val8 = 0;
int val9 = 0;
int analogValue1;
int analogValue2;
int analogValue3;
int analogValue4;
int analogValue5;
int audio;
 //Create Serial Object (9600 Baud)
 pinMode(button1, INPUT);
 pinMode(button2, INPUT);
 pinMode(button3, INPUT);
 pinMode(button4, INPUT);
int val1 = map(analogRead(0), 0, 1023, 0, 180);
int val2 = map(analogRead(1), 0, 1023, 0, 180);
int val3 = map(analogRead(2), 0, 1023, 0, 180);
int val4 = map(analogRead(3), 0, 1023, 0, 50);
int val5 = map(analogRead(4), 0, 1023, 0, 180);
val6 = digitalRead(button1);
val7 = digitalRead(button2);
val8 = digitalRead(button3);
val9 = digitalRead(button4);
if (val6 == HIGH) {
   Serial.println("A");
if (val7 == HIGH) {
   Serial.println("B");
if (val8 == HIGH) {
   Serial.println("C");
if (val9 == HIGH) {
   Serial.println("D");
if (val6 == LOW) {
   Serial.println("E");
if (val7 == LOW) {
   Serial.println("F");
if (val8 == LOW) {
   Serial.println("G");
if (val9 == LOW) {
   Serial.println("H");
Serial.write(',');
Serial.write(val1);
Serial.write(val2);
Serial.write(val3);
Serial.write(val4);
Serial.write(val5);
Serial.write(val6);
Serial.write(val7);
Serial.write(val8);
Serial.write(val9);
delay(25);
// I didn't put all the lighting code I just need to get this part fixed and working, this is the dome//
  Serial.begin(9600); //setup serial connection
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
    //initialize all our LED sections
    Radar.begin();
    Holo.begin();
    PSI.begin();
    Side.begin();
    // Kick off a pattern
    Radar.SolidColorRadar(Radar.Color(255,0,0));
    Holo.RainbowCycle(25);
    Side.Fade(Side.Color(0,0,100), Side.Color(0,0,05), 100, 40, REVERSE);
    PSI.SoundPulse();
// Main loop
void loop()  {
    if(Serial.available()> 0 )       // if data is available to read
    int val = Serial.read();         // read it and store it in 'val'
   //this switch is for creating various patterns based on the character received from the bluetooth module (or serial terminal from arduino software)
   switch (val) {
      case 'A':
        Radar.Scanner(Radar.Color(100,0,0), 100); // Radar scans Cylon style red with 100ms interval
        Holo.RainbowCycle(25);  //1ms fast rainbow cycle
        //PSI.SolidColorRadar(PSI.Color(0,0,100)); // set the PSU to solid blue
        Side.Random(200, 0,1,1); //Sides randomly blink at 200ms intervals red off, green on, blue on
        digitalWrite(9, HIGH);
      case 'B':
       // PSI.Fade(PSI.Color(0,0,100), PSI.Color(0,100,0), 500, 1, FORWARD); //fase from green to blue
        Holo.SolidColorRadar(Holo.Color(0,0,100)); //Holo solid blue
        digitalWrite(10, HIGH);
      case 'C':
        Radar.Scanner(Radar.Color(0,100,0), 100); //scan green
        Holo.RainbowCycle(25); //rainbow 25ms
        Side.TheaterChase(Side.Color(0,0,100), Side.Color(0,100,0), 50,  FORWARD); //lights chase green and blue 50ms
        digitalWrite(11, HIGH);
      case 'D':
        Radar.Scanner(Radar.Color(0,100,00), 100);
        Holo.RainbowCycle(1);
        //PSI.Fade(Radar.Color(0,0,255), Radar.Color(0,0,05), 25, 100, REVERSE);
        digitalWrite(13, HIGH);
      case 'E':
        digitalWrite(9, LOW);
      case 'F':
        digitalWrite(10, LOW);
      case 'G':
        digitalWrite(11, LOW);
      case 'H':
        digitalWrite(13, LOW);
Why?
You have declared 4 pins to be INPUT, but have not enabled the internal pullups. So, whatever is connected to those 4 pins needs to use external pullup or pulldown resistors. Post a wiring diagram showing the connections to those 4 pins.
Serial.write(',');
Serial.write(val1);
Serial.write(val2);
Serial.write(val3);
Serial.write(val4);
Serial.write(val5);
Serial.write(val6);
Serial.write(val7);
Serial.write(val8);
Serial.write(val9);
Serial.write() is for sending binary data. The write() method expects a byte argument, NOT an int argument. What does the function actually send? The high order byte? The low order byte? If you do not KNOW, do not call the function with the wrong type.
Why are val1 to val5 local while val6 to val9 are global? None of them should be global.
But WE need to see what all those objects are.
If there is at least one byte available to read, do nothing (that's what that body does). Otherwise, do nothing.
Then, regardless of whether there is data, or not, do something. It's hard to determine what this does. I'll need to study that comment for a while. 8)
You seem to be using Serial to talk to the XBee AND to the PC. Make up your mind which you want to use it for, and stop using it for the other purpose.
How are the XBees connected to the Arduinos? How are the XBees configured? What type of XBees are they?
What, exactly, is the problem?
