BBC microbit not uploading
It wont upload even though i have installed packages and an external config script.
WARNING: library NewPing claims to run on avr, arm, megaavr, esp32 architecture(s) and may be incompatible with your current board which runs on nRF5 architecture(s).
/home/usr_40476/.arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/Sketch uses 19440 bytes (7%) of program storage space. Maximum is 262144 bytes.
5.2.1/../../../../arm-none-eabi/bin/ld: warning: changing start of section .heap by 4 bytes
/home/usr_40476/.arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld: warning: changing start of section .stack_dummy by 4 bytes
/home/usr_40476/.arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld: warning: changing start of section .heap by 4 bytes
Open On-Chip Debugger 0.10.0-dev-00254-g696fc0a (2016-04-09-12:07)
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
swd
cortex_m reset_config sysresetreq
adapter speed: 1000 kHz
Error: unable to open CMSIS-DAP device 0xd28:0x204
Error: No Valid JTAG Interface Configured.
Failed uploading: uploading error: exit status 255
Welcome to the forum
Have you read and understood the first line of the error message ?
In addition to the above, the Arduino IDE is not set up correctly, according to the last line of the posted error message.
what should I do?
A suggestion would be to configure a JTAG interface programmer.
I dont know how to do that, I would like to note that my MEGA and UNO boards work just fine
I am using the .appimage file from the official download site. My OS is openSUSE Tumbleweed
You might try following the Adafruit guide: Overview | Micro:bit with Arduino | Adafruit Learning System
The guide includes instructions on how to handle the error you have encountered using linux (which you forgot to mention until post #6).
Hint: a web search for "program microbit arduino" turns up useful information.
Thank you! the article fixed my problem!
