BC548 or other transistor for 3×3×3 led cube
Hello,
I want to make a 3×3×3 led cube. I saw on the Internet that they use a transistor (mostly something like 2N2222) to do the trick. But I have a BC548. Can I use this one and wich resistor does it need? Or can I better use a MOSFET to do it? I is my first time I use transistor's.
Thanks
Robbe
Any typical small NPN transistor should work… Base resistor of 220 to 1000 should be OK.
My wife built a 3x3x3 and the code and library is HERE:
http://arduino-info.wikispaces.com/LED-CUBE-3X3
So my BC548 would work?
Hi, Should be OK...
See: https://www.semicon-data.com/transistor/tc/bc/BC348.html
Thanks for this!
