BCD clock
Dear Arduionists,
i have a problem with my new project, a binary clock in BCD-format.
13 leds display the 24 hours in 4 vertically columns: o o 8
o o o 4
o o o o 2
o o o o 1
tens ones | tens ones
hours | minutes
I hope, my drawing can explain you, how the leds are arranged and with a minimum of hardware the time will be displayed.
The led-array is common cathode and driven by a MAX7219 chip. It works well, in the display control mode all leds are lighting up.
So i can say, my circuit is ok.
But in running my program, <binary-clock.ino>, the leds are not switched in. Only a dim glowing shows me the time.
For example: the fixed time (in line 75), 13:57:39 h, is displayed with 6 leds.
The hour tens led, the hour twos led, all the minute leds are shiny, only the one minute led is “switched on”.
What is my fault?
Greetings bolsak.
[code]
/* binary_clock.ino
  SPI-pins: MOSI = D11,SCK = D13,SS = D10
  time-display with 13 led in BCD-format:
   8           0              0
   4           0      0       0
   2   0       0      0       0
   1   0       0      0       0
      hour   hour   minute  minute
      ten     one    ten     one
  2 additional leds show that the clock in "running"
  it is a common-cathode-array as in
  playground-arduino.cc/LEDMatrix/MAX7219
uint32_t runMillis;
uint32_t allSeconds, secsRemaining;
uint8_t hour, minute, second;
#include <SPI.h>
#include <binary.h>
const byte MAX7219_REG_NOOP         = 0x0;
const byte MAX7219_REG_DIGIT0       = 0x1; // 1. row
const byte MAX7219_REG_DIGIT1       = 0x2;
const byte MAX7219_REG_DIGIT2       = 0x3;
const byte MAX7219_REG_DIGIT3       = 0x4;
const byte MAX7219_REG_DIGIT4       = 0x5;
const byte MAX7219_REG_DIGIT5       = 0x6;
const byte MAX7219_REG_DIGIT6       = 0x7;
const byte MAX7219_REG_DIGIT7       = 0x8; // 8. row
const byte MAX7219_REG_DECODEMODE   = 0x9;
const byte MAX7219_REG_INTENSITY    = 0xA;
const byte MAX7219_REG_SCANLIMIT    = 0xB;
const byte MAX7219_REG_SHUTDOWN     = 0xC;
const byte MAX7219_REG_DISPLAYTEST  = 0xF;
void sendByte(const byte reg, const byte data)
{ digitalWrite(SS, LOW);
  SPI.transfer (reg);
  SPI.transfer (data);
  digitalWrite(SS, HIGH);
char  buf[21];            // Serial.print
const byte Bell =  9;     // bell / loudspeaker
void GetTime() {
  runMillis = millis();
  allSeconds = millis() / 1000;
  hour = allSeconds / 3600;
  secsRemaining = allSeconds % 3600;
  minute = secsRemaining / 60;
  second = secsRemaining % 60;
  Serial.println(" =========== binary_clock.ino ==================== ");
  Serial.println(" =============================== 20.11.2020 ====== ");
  pinMode(Bell, OUTPUT);
  SPI.begin();
  sendByte (MAX7219_REG_SCANLIMIT, 2);   // 0 ... 7  2 rows
  sendByte (MAX7219_REG_DECODEMODE, 0);  // single LED=0
  sendByte (MAX7219_REG_DISPLAYTEST, 0); // display = 0, Test=1
  for (byte col = 0; col < 8; col++)    // clear Display
  { sendByte(col + 1, 0);
    sendByte (MAX7219_REG_INTENSITY, 9);  // 0 .. 15
    sendByte (MAX7219_REG_SHUTDOWN, 1);  //
  hour = 13; minute = 57; second = 39;    // fixed time for testing
} //                   ====== setup ===
void loop() {  //
  //GetTime();
  sprintf(buf, "   % 2d:%02d:%02d ", hour, minute, second);
  // ============================ output ============   minute-ones
  (minute % 10 == 1 || minute % 10 == 3 || minute % 10 == 5 || minute % 10 == 7 || minute % 10 == 9)
  ? sendByte(1, 128)    :   sendByte(1, 0);
  (minute % 10 == 2 || minute % 10 == 3 || minute % 10 == 6 || minute % 10 == 7)
  ? sendByte(1, 64)    :   sendByte(1, 0);
  (minute % 10 == 4 || minute % 10 == 5 || minute % 10 == 6 || minute % 10 == 7)
  ? sendByte(1, 32)    :   sendByte(1, 0);
  (minute % 10 == 8 || minute % 10 == 9)
  ? sendByte(1, 16)    :   sendByte(1, 0);
  // =============================================================   minute-tens
  (minute / 10 == 1 || minute / 10 == 3 || minute / 10 == 5 || minute / 10 == 7 || minute / 10 == 9)
  ? sendByte(1, 8)    :   sendByte(1, 0);
  (minute / 10 == 2 || minute / 10 == 3)   ? sendByte(1, 4)    :   sendByte(1, 0);
  (minute / 10 == 4 || minute / 10 == 5)   ? sendByte(1, 2)    :   sendByte(1, 0);
  //  ==============================================================  hour-ones
  (hour % 10 == 1 || hour % 10 == 3 || hour % 10 == 5 || hour % 10 == 7 || hour % 10 == 9)
               ? sendByte(1, 1)    :   sendByte(1, 0);
  (hour % 10 == 2 || hour % 10 == 3 || hour % 10 == 6 || hour % 10 == 7)
               ? sendByte(2, 128)    :   sendByte(2, 0);
  (hour % 10 == 4 || hour % 10 == 5 || hour % 10 == 6 || hour % 10 == 7)
               ? sendByte(2, 64)    :   sendByte(2, 0);
  (hour % 10 == 8 || hour % 10 == 9)   ? sendByte(2, 32)    :   sendByte(2, 0);
  // ==============================================================     hour-tens
  (hour / 10 == 1 || hour / 10 == 3)  ? sendByte(2, 16)   :   sendByte(2, 0);
  (hour / 10 == 2 )                   ? sendByte(2, 8)    :   sendByte(2, 0);
  Serial.print(buf);
[/code]
But my problem now is, i can’t work with SPI.
but using the SPI protocol gives me no equal and bright
@bolsak
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
