JohnSan
1
Looking to convert a 'long to bcd' to drive 5 led displays.
(HP5082 -7302)
Is there a function in a library somewhere to do this, or will it have to be done from scratch.
I know things have moved on since these were about, but would just like to use them....
TIA.
I'm sure there's a more efficient way to code this.
void BCD (unsigned long b, char* o)
for (int i=10; i; --i)
*o = b % 10;
b /= 10;
o++;
system
3
mkwired:
*o = b % 10;
b /= 10;
o++;
Shouldn't you be packing two digits per byte (one nibble per digit) if you're outputting BCD?
PeterH:
mkwired:
*o = b % 10;
b /= 10;
o++;
You're probably right, but his wasn't clear what he wanted.
And probably should use byte (which is unsigned) instead of char (which is signed).
I thought about that but the stored values are small enough that it doesn't really matter.
the basic BCD packaging:
uint8_t dec2bcd(uint8_tdec)
return (dec/10)*16 + (dec%10);
uint8_t bcd2dec(uint8_t bcd)
return (bcd/16) * 10 + bcd%16;
For longer numbers one need a BCD array
JohnSan
8
Thanks for the info.
The 'data' to be displayed presently, is just a counter.
The solutions are somewhat more simple than i'd anticipated.
Which is great news!
I've found the displays are actually HP5082 -7340
- which means, I can display the number in Decimal or Hex
Of course in Hex, I won't need to use the conversion.
