I am getting the following error
Binary sketch size: 3124 bytes (of a 14336 byte maximum)
avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0xfe
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0xe6
avrdude: stk500_cmd(): programmer is out of sync
I can load and run the Blink LED sketch just fine. The code compiles fine. Is this just not running because I don't have things all hooked up yet and the board is expecting to read some values from multiplexer chips? Make: Make: Vol. 85 Here's the project Anyone see any other issues? Here's the code
- Beatbearing firmware
- Peter Bennett
- pete@petecube.com
- NOTE:
- this isn't the most efficiently coded program, but is the one that I was using as a prototype
- when writing up the BeatBearing article
- Keep an eye on www.beatbearing.co.uk for suggested updates to this firware,
- including a version with proper debouncing and use of the digital pins for input.
- Make sure to choose correct board and serial port before programming
- This was written in Arduino v12
*/int A0_1 = 2; // declare output pins
int A1_1 = 3;
int A2_1 = 4;
int A3_1 = 5;
int A0_2 = 6;
int A1_2 = 7;
int A2_2 = 8;
int A3_2 = 9;int Z_1 = 0; // declare input pins
int Z_2 = 1;int thresholdLow = 3000;
int thresholdHigh = 7000;int stateMatrix[32][8] = { // stores all of the values.
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0};int averages[32] = { // stores all of the values.
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0};boolean bState[32] = {
B0, B0, B0, B0, B0, B0, B0, B0,
B0, B0, B0, B0, B0, B0, B0, B0};void setup() {
pinMode(A0_1, OUTPUT); // set outputs
pinMode(A1_1, OUTPUT);
pinMode(A2_1, OUTPUT);
pinMode(A3_1, OUTPUT);pinMode(A0_2, OUTPUT);
pinMode(A1_2, OUTPUT);
pinMode(A2_2, OUTPUT);
pinMode(A3_2, OUTPUT);
}void loop(){
byte byteOut1 = B00000000;
byte byteOut2 = B00000000;
byte byteOut3 = B00000000;
byte byteOut4 = B00000000;
byte byteOut5 = B00000000;
byte stopByte = B11111111;for (int a = 0; a < 32; a++) { // first shift all old values up
for (int b = 7; b > 0; b--) {
stateMatrix[a] = stateMatrix[a][b-1];
** for (long count = 0; count < 16; count++) { // now get all the states 0-1024**
** digitalWrite(A0_1, (count >> 3) & 1);**
** digitalWrite(A1_1, (count >> 2) & 1);**
** digitalWrite(A2_1, (count >> 1) & 1);**
** digitalWrite(A3_1, (count >> 0) & 1);**
** digitalWrite(A0_2, (count >> 3) & 1);**
** digitalWrite(A1_2, (count >> 2) & 1);**
** digitalWrite(A2_2, (count >> 1) & 1);**
** digitalWrite(A3_2, (count >> 0) & 1);**
** stateMatrix[count][0] = analogRead(Z_1); // and insert new values at position 0**
** stateMatrix[count + 16][0] = analogRead(Z_2);**
** for (int a = 0; a < 32; a++) { // now calculate averages**
** averages[a] = 0;**
** for (int b = 0; b < 8; b++) {**
__ averages[a] += stateMatrix[a];__
** // determine binary state using thresholds**
** for (int n = 0; n < 32; n++) {**
** if ((bState[n] == B0) && (averages[n] < (thresholdLow))) { // last sure value was 0 AND below low threshold**
** bState[n] = B1; // then set to 1;**
** else if ((bState[n] == B1) && (averages[n] > (thresholdHigh))){ // last sure value was 1 AND over high threshold**
** bState[n] = B0; // set to 0;**
** // now assemble the output bytes**
** int stateCount = 0;**
** // first byte**
** for (int n = 0; n < 7; n++) {**
** if (bState[stateCount] == B1) {**
** byteOut1 |= (1 << n); // then set to 1;**
** else {**
** byteOut1 &= ~(1 << n); // set to 0;**
** stateCount++;**
** // second byte**
** byteOut2 |= (1 << n); // then set to 1;**
** else {**
** byteOut2 &= ~(1 << n); // set to 0;**
** stateCount++;**
** // third byte**
** byteOut3 |= (1 << n); // then set to 1;**
** else {**
** byteOut3 &= ~(1 << n); // set to 0;**
** stateCount++;**
** // fourth byte**
** byteOut4 |= (1 << n); // then set to 1;**
** else {**
** byteOut4 &= ~(1 << n); // set to 0;**
** stateCount++;**
** // fifth byte (shorter than others)**
** for (int n = 0; n < 4; n++) {**
** byteOut5 |= (1 << n); // then set to 1;**
** else {**
** byteOut5 &= ~(1 << n); // set to 0;**
** stateCount++;**
** // send the values over serial to Processing**
** Serial.print(byteOut1, BYTE);**
** Serial.print(byteOut2, BYTE);**
** Serial.print(byteOut3, BYTE);**
** Serial.print(byteOut4, BYTE);**
** Serial.print(byteOut5, BYTE);**
** Serial.print(stopByte, BYTE);**
[/quote]
