Beating head against wall with a simple project...
I am trying to get a simple button project to work and its making me crazy...
Push button and scroll between All/Red/Blue/Green on a RGB LED
It gets stuck in a loop between state 1 & 3
// this constant won't change:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
const int redPin = 9;   // Red LED,   connected to digital pin 9
const int grnPin = 10;  // Green LED, connected to digital pin 10
const int bluPin = 11;  // Blue LED,  connected to digital pin 11
// Variables will change:
int stateNum = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
int redVal = 0;   // Variables to store the values to send to the pins
int grnVal = 0;
int bluVal = 0;
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(redPin, OUTPUT);
  pinMode(grnPin, OUTPUT);
  pinMode(bluPin, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
 if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH)
    { stateNum++;
      if (stateNum>3) stateNum=0;
      Serial.println("on");
      Serial.print("State Number:  ");
      Serial.println(stateNum);
      digitalWrite(ledPin, HIGH);
    { Serial.println("off");
      digitalWrite(ledPin, LOW);
    // Delay a little bit to avoid bouncing
    delay(10);
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  if (stateNum = 0) //White
 {  Serial.println("1 White");
    grnVal = 255;
    bluVal = 255;
    redVal = 255;
else if (stateNum = 1) //Green
 {  Serial.println("1 Green");
    grnVal = 255;
    bluVal = 0;
    redVal = 0;
else if (stateNum = 2) //Blue
 {  Serial.println("2 Blue");
    bluVal = 255;
    redVal = 0;
    grnVal = 0;
else (stateNum = 3); //Red
 {  Serial.println("3 Red");
    redVal = 255;
    grnVal = 0;
    bluVal = 0;
 analogWrite(redPin, redVal);   // Write values to LED pins
 analogWrite(grnPin, grnVal);
 analogWrite(bluPin, bluVal);
dont u mean----
else if (stateNum == 1) //Green
Yup - that's the issue.
= is assignment.
== is comparison.
Thanks, but that didnt resolve it :frowning:
its still stuck in a loop between 0&3 (not 1, I was wrong)
the first half is fine, I tested it... its in here:
if (stateNum == 0)
{ Serial.println("0 White");
grnVal = 255;
bluVal = 255;
redVal = 255;
grnVal = 255;
bluVal = 0;
redVal = 0;
else if (stateNum == 2) //Blue
bluVal = 255;
redVal = 0;
grnVal = 0;
else (stateNum == 3); //Red
redVal = 255;
grnVal = 0;
bluVal = 0;
Responding to Reply #3
You have = in other places where it should be ==. Check your program carefully.
...R
I found it, thanks!
