Beehive security System: Arduino + SIM800L gprs + GPS module + tilt sensor
Hello,
I'm finishing a project to protect my bee hives without counting the lipo battery, it cost me less than € 30
It's about connecting a SIM800L module, with a ThingsMobile SIM card (which has a virtually universal coverage), and a very low consumption when sending short text messages.
I do not want to send SMS, because they are expensive. My tactic is another: send short text messages, for example, send latitude and longitude to a certain web, with the POST protocol. Receive the data in a php of the server, and send from the php an email to my mail if there is an alarm.
A gprs module, a GPS module and a tilt sensor are connected to Arduino, so that if someone moves the hive, an alarm is created sending GPS data.
This is the php file that is on the server:
<?php
    $DATE = gmdate("Y-m-d H:i:s");
     $LAT = htmlspecialchars($_POST['lat'],  ENT_QUOTES, "UTF-8");
     $LON = htmlspecialchars($_POST['lon'],  ENT_QUOTES, "UTF-8");
     if (strlen($LAT) < 1)
       goto end;
     $message = "warning! The hive has been moved! lat = " . $LAT .  "
 lon = " . $LON . "
     $to = "myweb@gmail.com";
     $subject = $DATE;
     mail($to, $subject, $message);
     end:
This is the function that sends the data:
char kate[99];
void gprs_appendPOST_webhost(char data[], int length)
  Serial.println("\n\nHTTP post method :\n");
  /* Check Communication */
  sim800.write(27);
  sim800.println("AT");
  sim800SerialData(); // OK
  delay(50);
  // SIM card inserted and unlocked?
  sim800.println("AT+CPIN?");
  delay(555);
  sim800SerialData(); // +CPIN: READY
  delay(50);
  // Is the SIM card registered?
  sim800.println("AT+CREG?");
  delay(555);
  sim800SerialData(); // +CREG: 0,1  OK
  delay(50);
  // Is GPRS attached?
  sim800.println("AT+CGATT?");
  delay(555);
  sim800SerialData(); // +CGATT: 1  OK
  delay(50);
  // Check signal strength - should be 9 or higher
  sim800.println("AT+CSQ");
  delay(555);
  sim800SerialData(); // +CSQ: 14,0  OK
  delay(50);
  // Reset the IP session if any
  sim800.println("AT+CIPSHUT");
  delay(555);
  sim800SerialData();
  delay(50);
  /* Configure bearer profile 1  Connection type GPRS */
  sim800.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
  delay(50);
  /* APN of the provider */
  //AT+SAPBR=3,1,"APN","wholesale"
  sim800.println("AT+SAPBR=3,1,\"APN\",\"TM\"");
  delay(555);
  delay(50);
  // Enable GPRS - this will take a moment or two
  sim800.println("AT+SAPBR=1,1");
  sim800SerialData();
  delay(50);
  // Check to see if connection is correct and get your IP address
  // (I hid mine here, but you'll get a real IP back)
  sim800.println("AT+SAPBR=2,1");
  delay(5000);
  sim800SerialData(); // +SAPBR: 1,3,"0.0.0.0" OK
  delay(50);
 /*  Terminate HTTP service */
  sim800.println("AT+HTTPTERM");
  sim800SerialData();
  delay(50);
  // Initialize HTTP service or enablke HTTP mode
  sim800.println("AT+HTTPINIT");
  delay(5555);
  delay(50);
  // Set parameters for HTTP session: Set HTTP profile identifier
  sim800.println("AT+HTTPPARA=\"CID\",1");
  delay(5000);
  delay(50);
   sim800.println("AT+HTTPPARA=\"URL\",\"http://myweb.com/gprs/GPSpost.php\"");
  delay(5555);
  sim800.println("AT+HTTPPARA=CONTENT,application/x-www-form-urlencoded");:
  delay(5555);
  sim800SerialData();
  sprintf(kate, "AT+HTTPDATA=%d,10000", luze);
  sim800.println(kate);
  delay(5000);
  sim800SerialData(); // DOWNLOAD
  delay(50);
  sim800.println(datuak);
  delay(5000);
  delay(50);
  // Post the data - wait a second for the response
  sim800.println("AT+HTTPACTION=1");
  delay(5000);
  sim800SerialData(); //  +HTTPACTION:1,200,142 OK
  delay(50);
  // URL where you can confirm that it's working
   sim800.println("AT+HTTPREAD");
   delay(5000);
   sim800SerialData(); //   +HTTPREAD:142
   delay(50);
  // Close the HTTP connection
  delay(5000);
  delay(50);
   // Disconnect the GPRS
   sim800.println("AT+SAPBR=0,1");
   delay(5000);
   delay(50);
char data[222];
char txtlat[33], txtlon[33];
 float flat, flon;
int length;
  if(tilt == 1)
     gps_NEO6M.listen();
     read_gps();  // flat = -22.34;  // flon = 111.34;
     strcpy(txtlat, ftoa(flat));
     strcpy(txtlon, ftoa(flon));
     sprintf(data, "lat=%s&lon=%s", txtlat, txtlon);
      length = strlen(data);
      delay(2222);
      sim800.listen();
      gprs_appendPOST_webhost(data, strlen(data));
      Serial.write(data);
      Serial.write( " length:");
      Serial.print(strlen(data));
  delay(6000);
